NoNo_BadDog
May 20, 2018Star
RBK50 IPv6 Stops Working
About every 24 hours IPv6 stops functioning on my system. Verified via http://ipv6-test.com. I have to login and click apply in the IPv6 setting and it starts working again for about 24 hours. I h...
NoNo_BadDog
May 21, 2018Star
The modem is an Arris TM822 and IPS is Comcast. I will try a reboot and monitor. If it happens after rebooting I will do a factory reset.
May 21, 2018Guru - Experienced User
Is the modem bridged or a stand alone modem? Not built in router. The TM822 comes in a TM822g which has a built in router...
