NoNo_BadDog
May 20, 2018Star
RBK50 IPv6 Stops Working
About every 24 hours IPv6 stops functioning on my system. Verified via http://ipv6-test.com. I have to login and click apply in the IPv6 setting and it starts working again for about 24 hours. I h...
May 21, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem the orbi is connected too?
Try a full reboot of the router and test again. If it still happens, try a full factory reset of the router and set up from scratch...
Joechang
Jan 09, 2019Apprentice
I have seen your thoursands of reply repeting rebot and factory reset, pls stop and it deesnt work 100%
- michaelkenwardJan 10, 2019Guru - Experienced User
Maybe not for you but it does work for some %.
Feel free to ignore messages that do not apply to you but that may help other users.
