Jpetrarca4
Sep 20, 2021Aspirant
Rbk50 issues with wired backhaul fw 2.7.3.22
Hi guys wondering if anyone could help me, I wired my satellite in lan port2. I have rbk50 one satellite. Latest firmware 27322. I have a few issues since doing this. It seams like my range now is not...
Sep 20, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Are the RBS connected directly behind the RBR or is there a LAN switch in between them?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter,
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- Jpetrarca4Sep 20, 2021Aspirant
the system was factory reset after connecting the wired backhaul, i am using a verizon ONT, everything is connected directly with no switches. my home is a raised ranch, two floors, each about 1000sq ft. they are probably 20 ft apart with a wall seperating them. i had the channels on auto, i just changed them to the recommended setting on the post you copied. i still cant get the satellite to show in the app as connected. also i show all devices connected to router which isnt the case if i go into the satellites ip address and can see about 10 devices connected so im not sure.
- Jpetrarca4Sep 20, 2021AspirantNvmd, going and changing the channels from auto to 1 and 36, setting the satellite to a static ip must of helped because the satellite now shows up in the app. Thanks
- Jpetrarca4Sep 20, 2021AspirantSpoke too soon. It has reverted back to showing no satellites and the network map has the satellite purple in the app. Orbi login shows the satellite. Can’t see what’s connected to it. Unless I go through the op address but it doesn’t show the devices. Just says unknown. Would love to be able to view it through the app correctly.
- FURRYe38Sep 20, 2021Guru - Experienced User
Id bring the RBS to same room as the RBR and directly connect them to the RBR in back using CAT6 lan cabling. Observe the top ring LED to see if these turn ON when you connect them. Give them about 5 minutes to settle in then check the app.
