Jpetrarca4
Sep 20, 2021Aspirant
Rbk50 issues with wired backhaul fw 2.7.3.22
Hi guys wondering if anyone could help me, I wired my satellite in lan port2. I have rbk50 one satellite. Latest firmware 27322. I have a few issues since doing this. It seams like my range now is not...
Sep 20, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Are the RBS connected directly behind the RBR or is there a LAN switch in between them?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter,
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Jpetrarca4
the system was factory reset after connecting the wired backhaul, i am using a verizon ONT, everything is connected directly with no switches. my home is a raised ranch, two floors, each about 1000sq ft. they are probably 20 ft apart with a wall seperating them. i had the channels on auto, i just changed them to the recommended setting on the post you copied. i still cant get the satellite to show in the app as connected. also i show all devices connected to router which isnt the case if i go into the satellites ip address and can see about 10 devices connected so im not sure.
