altgml11
Dec 27, 2022Tutor
RBK50 Keeps Dropping all Connections
my RBK50 has been acting up for the last few weeks. The speed had to 300Mbps on a Gigabit connection, drops all connections once or twice a day, and then comes back up (The logs don't show anything o...
Dec 27, 2022Guru - Experienced User
What actual modem is it connected to?
I know the light is green, but when it goes down, do hardwired devices work?
What firmware is on the satellites? (not just the router)
altgml11
Dec 28, 2022Tutor
It's connected to an Arris tg3452a modem and the satellite and the router are on the same firmware. I've checked the modem periodically and it clocks 900Mbps continuously. I'm leaning more toward the router because it fully disconnects the connections. i've had one or two minor ISP outages in the last year and in all those cases, my devices were still connected to the Router Wifi (even though the modem lacked internet access).
- plemansDec 28, 2022Guru - Experienced User
That modem? Isn't just a modem.
Its a modem/router combo device and causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode- altgml11Dec 28, 2022TutorThanks a lot for the detailed response! Sorry, should've put this in my original post, but it's already in the bridge mode and it's strictly used as a modem with the Orbi handling the Wifi.
- chlaloeKKDec 29, 2022Aspirant
Thanks for sharing this knowledgeable insights for router, it helped me a lot with working on the page.
- maruti7766Dec 29, 2022Aspirant
That's great information! Double NAT can be a tricky, but it sounds like you've got it all figured out. I think the best option for most people would be to put the modem/gateway in modem only/pass through mode, as this will disable its routing functions and help to prevent interference. Thanks for sharing!
- KevinLiTDec 29, 2022NETGEAR Moderator
Hello Maruti7766,
Welcome to the NETGEAR Community!
Soliciting is not tolerated in the community.
Your link has been removed.
For more information about our community guidelines please visit the page below:
NETGEAR Community Terms Of Service | Answer | NETGEAR Support
Best,
Kevin
Community Team
