xMav
Mar 16, 2021Aspirant
RBK50 LAN ports causing packet loss.
My network started to become unreliable a few days back. My fios internet was seeing 2-20% packetloss.
I moved the orbi right next to my FIOS ONT and used a new patch cable and the problem persisted.
I plugged my laptop directly into the ONT and the problem disapeared.
The only thing that confused me as to why maybe its not orbi is if i ping the orbi gw i have no issue (verizon ONT)
I go anything past that and there is an issue.
has anyone else seen this behavior? Suggestions?
I don't understand that inconsistency. Why i get packet loss to 8.8.8.8 but the orbi gw if the issue is with the orbi.
Directly connecting a pc or pluggin my nighthawk back in fixes the issue.
1 Reply
- xMavAspirant
More info:
If i use my R8000 Nighthawk w/ wifi disabled and put the orbi in AP mode my pings are reliable.
SO that indicates its likely the WAN port that has some kind of hardware or software issue.
I did not do any firmware updates that could ahve caused this. I did after it started and it did not help.
Again though, why can i reliably ping the ip of the ONT through the orbi wan but not google. Maybe some kind of strange MTU issue?
I might just be done with netgear hardware. My stupid R8000 only gets 300/300 on my gig connection. Its apparently a known bug many reported with multiple firmware versions. It randomly reboots(somtimes twice a week sometimes once every 2-3 weeks. Which is why i got the orbi.
And now my Orbi is appears broken. Negear offers no support outside 90 days which is crazy to me. I pay less for cisco meraki support per value of the hardware than Netgear is asking.
I was heavy into netgear, with the arlo pro and gaming networking gear. Now orbi is the last of it all for reliablity reasons. :(
(to be fair i think the arlo issue was actually a wifi issue with my nighthawk. My sister has used it for the past year w/o issue.)
I ordered a Eero 6 pro just incase i could not fix this hopeing i would return it. But looks like in 2 days ill be installing it unless someone here has a fantastic idea that may turn this thing around.
Thanks to anyone that took the time to read this.
