carlsson
Jul 05, 2021Star
RBK50 low speed on some spots
I bought the RBK50 system last summer, ie one RBR50 and two RBS50. This have worked very good, except that I have some spots with lower speeds. Our house is built 1926, it has an indoor chimney t...
carlsson
Jul 05, 2021Star
Thanks for the input Plemans. đ
The probem is especially visible on the second floor, I get as low as 5 Mbit/s depending on where and how I put the satellite. It may be the bricks in the chimney, as well as things in the walls.
I'll try to add a second satellite on that floor.
Jul 05, 2021Guru - Experienced User
Just for testing, move them around. You have 2x satellites and a router so you could potentially try a lot of combinations to see how to get the best coverage on that floor.
