Globi
Oct 09, 2017Aspirant
RBK50 no apple watch wifi connection
Hi Usually the apple watches connect via wifi when its on the same network as the iphone but not within bluetooth range. This works in all the wifi networks I have access to even a mesh network u...
aaz
Oct 11, 2017Virtuoso
Did you make any progress on this?
Globi
Oct 11, 2017Aspirant
Yes I could solve the problem:
1. Disconnect iPhone from wifi Network ‚ignore‘
2. Turn off Bluetooth on the iPhone
3. Switch off apple watch
4. Reconnect wifi on iPhone (reentering password needed)
5. Turn on Bluetooth on the iPhone
6. Turn on apple watch again.
I cannot figure out if it was a orbi.specific problem or more a problem of the iPhone and the apple watch, but I dont care as long as it works now.
Greets
- aazOct 11, 2017Virtuoso
I've also seen Orbi issues where some devices are not showing up as connected on the Orbi device list, but they are connected on the wireless. Not sure if that is supposedly fixed in latest firmware, but maybe not completely.
- jschwalbeDec 03, 2017Initiate
This has worked for me in the past, but it eventually (for some reason) stops working. How long has this solution worked for you?
- oldcakeDec 15, 2017Aspirant
homekit device with 2.4G wifi is same problem.
