PDown
Aug 17, 2018Aspirant
RBK50 no internet with Spectrum Modem
Hello, I recently made an internet provider switch and I need some setup help with my Orbi. I previously had AT&T Uverse with a cable modem. Out of the cable modem, I directly hooked up my Orbi router...
- Aug 19, 2018
Hey, thanks for the reply. The solution ended up being to return the modem and router, and get an Arris modem from them, and go through the setup process again - everything worked smoothly, just as I had thought it would have the first time. So, I have gotten to where I wanted to be, with simply the modem piping directly into the Orbi system. Thanks!
Aug 20, 2018Guru - Experienced User
IT's recommended to have a stand alone modem vs a combo unit. Glad it worked out. Enjoy. :smileywink:
