pobbard
Feb 01, 2025Tutor
RBK50 no longer reliably connects to Google services
I've been running an RBK50 (1 RBR50 and 1 RBS50) with almost no issues for over 5 years. Lately, however, I've noticed that certain devices (typically our iPhones or my iPad) connected to the ...
Feb 02, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
Try custom DNS on the RBR instead of the ISP detected DNS.
