cganne
Mar 21, 2021Aspirant
RBK50 Not blocking on school Mac Air
hi, I have this RBK50, able to block the traffic and able to control on every device on my home, except the school Macbook Air given by my kid's school. Parential control works very good on rest,...
CrimpOn
Mar 21, 2021Guru - Experienced User
(Not using Circle myself, but....) How does Circle identify a device that should be managed? (Is it by MAC address?)
The most recent Apple software versions have a feature to create artificial MAC addresses rather than use the actual hardware MAC address. It is an option that can be turned on or off.
There is a community forum specifically for the Circle product where users may have personal experience to share:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
cganne
Thank you very much for your reply. I'll chk that route. Since its a school laptop..I do not have access to change any, but will try.
Yes in circle I identify it by Mac and the name and assigned it to my son's profile.
- CrimpOnMar 21, 2021Guru - Experienced User
Yes in circle I identify it by Mac and the name and assigned it to my son's profile.Might be worth verifying that the MAC address remains the same every time the laptop is connected to WiFi.
There are numerous articles on the web showing where in iOS this feature can be disabled, such as:
https://help.firewalla.com/hc/en-us/articles/360055342613-How-to-turn-off-MAC-Address-Randomization-
The school obviously has to allow users to access some parts of the WiFi settings so that they can log onto their home WiFi network.
- cganneMar 22, 2021Aspirant
yea...I checked I do not have the permissions and so planning to talk to school. On the circle , I have a catch all profile and even in that profile I did block the site, game app, etc. Still this is the only one going thru, rest of the systems (in catch all) are getting blocked.
Its bit frustrating . My wife works at a hostpital and on her apple laptop these filters are working. I need to check both of these laptops and their versions.
