alanbc's avatar
alanbc
Star
Mar 30, 2024
RBK50 or MK63
I have an Orbi RBK50 and satellite setup that's worked pretty well for a year or so, although I've never been completely happy with the admin UI and particularly annoyed that the UI doesn't always sh...
  • michaelkenward's avatar
    Mar 31, 2024
    You could start by working out why the Orbi fell over. Begin by telling people what modem/gateway/ONT sits between the router and the Internet.
    If you can work out solve the original problem, and if you can fix it, you can decide whether to return the MK63 system.
    Otherwise it is your call.
