petersuarez
Mar 29, 2019Aspirant
RBK50 Orbi AC3000: Two Smart TV's won't make LAN Connections
Both my LG and Sony TV's will not recognize the LAN connection. Two seperate manufacturers, it must be a setting within the Orbi Router.
Support has been nothing short of maddening. They just tel...
- Apr 29, 2019
Glad you found the problem. Was wondering.
Mark your thread and solved so others will know.
Enjoy. :smileywink:
petersuarez wrote:
Thanks for your reply but my issue was resolved.
Faulty cables was the issue.
All good now. The Orbi's solid.
petersuarez
Hello and thanks for your reply.
I've got a Spectrum Modem, Model E31T2V1
I ran an update on my LG TV and it came back that it was updated.
Cables are all solid.
I've looked like crazy on the LG and I simply can't find where to set Auto Obtain Network Address. I've been inside out of the Network Set up and I just don't see that setting.
UGH!
Mar 29, 2019Guru - Experienced User
UGH!
This is from the LG website for LgOS
https://www.lg.com/uk/support/solutions/tv/smart-tv/connecting-to-internet
Did you try this?
- petersuarezApr 01, 2019Aspirant
Yes, that's exactly how my set up looks on my LG. But still, no luck.
