petersuarez
Mar 29, 2019Aspirant
RBK50 Orbi AC3000: Two Smart TV's won't make LAN Connections
Both my LG and Sony TV's will not recognize the LAN connection. Two seperate manufacturers, it must be a setting within the Orbi Router.
Support has been nothing short of maddening. They just tel...
- Apr 29, 2019
Glad you found the problem. Was wondering.
Mark your thread and solved so others will know.
Enjoy. :smileywink:
petersuarez wrote:
Thanks for your reply but my issue was resolved.
Faulty cables was the issue.
All good now. The Orbi's solid.
petersuarez
Apr 02, 2019Aspirant
The manufacturer of the original router Sagemcom.
Attached is a picture.
I actually was on the phone with Spectrum and they adjusted the setting to 'Bridge' for the modem.
I reset to factory setting on the LG and that didn't work.
Apr 02, 2019Guru - Experienced User
Ok I was curious what you had. Thats a modem router combo.
Adjusting the modem you have not will not make any differences. I presume the proble is between the RBR lan ports and the TV lan ports.
You can try this then, get a inexpensive LAN swtich and see if this helps.
Only other way to see if it's the TVs or the RBR would be to put in a different router in place of the RBR temporarily and see if the TVs get an IP address. If they do off a different router, then there is something wrong with the Orbi or some kind of incompatibility issue. You could try another Orbi system and see as another suggestion.
- petersuarezApr 02, 2019Aspirant
What are your thoughts on the fact that both LG and Sony TV won't work? Two seperate manufactureres. Yet my wife's computer works fine on the wired. Before I got the Orbi, Spectrum's modem and router combo worked fine for the TV's.
Regarding the structure of the switch. TV wires connect into switch and the switch connects to the RBR?
- ekhalilApr 02, 2019MasterI think that somehow, in some cases after changing a router the TVs get stuck and cannot get new DHCP addresses.
Please test to set static IP addresses in the TVs to see if this is the issue. - FURRYe38Apr 02, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch?
Seems to be some kind of compatibility issue between the TVs and Orbi. Do the TVs get any IP address if directly connected to the RBR?
- LostInAustinApr 27, 2019AspirantSo I ran into this with my LG TV with a wired Ethernet connection.
It was extremely frustrating.
It’s because your Orbi wants an admin password.
Go to the WebOS app on the TV and pick a site. It will prompt you for an account name and password.
Use the admin account and password that you set up on your router.
You should be able to connect your apps after that.
- FURRYe38Apr 29, 2019Guru - Experienced User
Any progress on this?
