petersuarez
Mar 29, 2019Aspirant
RBK50 Orbi AC3000: Two Smart TV's won't make LAN Connections
Both my LG and Sony TV's will not recognize the LAN connection. Two seperate manufacturers, it must be a setting within the Orbi Router.
Support has been nothing short of maddening. They just tel...
- Apr 29, 2019
Glad you found the problem. Was wondering.
Mark your thread and solved so others will know.
Enjoy. :smileywink:
petersuarez wrote:
Thanks for your reply but my issue was resolved.
Faulty cables was the issue.
All good now. The Orbi's solid.
Apr 02, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch?
Seems to be some kind of compatibility issue between the TVs and Orbi. Do the TVs get any IP address if directly connected to the RBR?
petersuarez wrote:
What are your thoughts on the fact that both LG and Sony TV won't work? Two seperate manufactureres. Yet my wife's computer works fine on the wired. Before I got the Orbi, Spectrum's modem and router combo worked fine for the TV's.
Regarding the structure of the switch. TV wires connect into switch and the switch connects to the RBR?
LostInAustin
Apr 27, 2019Aspirant
So I ran into this with my LG TV with a wired Ethernet connection.
It was extremely frustrating.
It’s because your Orbi wants an admin password.
Go to the WebOS app on the TV and pick a site. It will prompt you for an account name and password.
Use the admin account and password that you set up on your router.
You should be able to connect your apps after that.
- petersuarezApr 29, 2019Aspirant
- FURRYe38Apr 29, 2019Guru - Experienced User
Enjoy. :smileywink:
Turns out that my electrician from 2 years ago had attached the end of the eternet incorrectly. The thing you actually plug into the TV was backwards. For whatever reason the connections stopped working when I introduced the Orbi.
