petersuarez
Mar 29, 2019Aspirant
RBK50 Orbi AC3000: Two Smart TV's won't make LAN Connections
Both my LG and Sony TV's will not recognize the LAN connection. Two seperate manufacturers, it must be a setting within the Orbi Router.
Support has been nothing short of maddening. They just tel...
- Apr 29, 2019
Glad you found the problem. Was wondering.
Mark your thread and solved so others will know.
Enjoy. :smileywink:
petersuarez wrote:
Thanks for your reply but my issue was resolved.
Faulty cables was the issue.
All good now. The Orbi's solid.
petersuarez
Apr 29, 2019Aspirant
Turns out that my electrician from 2 years ago had attached the end of the eternet incorrectly. The thing you actually plug into the TV was backwards. For whatever reason the connections stopped working when I introduced the Orbi.
Apr 29, 2019Guru - Experienced User
Ah ha. Yes incorrect LAN cable wiring can cause problems.
Glad you found it. :smileywink:
