GKACK
Dec 18, 2017Tutor
RBK50 Orbi Router- Wifi pw does not show correctly in web interface or Genie app after firmware upgr
I have used an 11 character wifi password that includes 2 special characters. No issues until a recent firmware upgrade to the 2.1.1.12 version. I had missed several firmeware versions since the upd...
DarrenM
Dec 20, 2017Sr. NETGEAR Moderator
I know there are some issues with spaces being in passwords and $ signs we are going to fix those in the next firmware.
DarrenM
- webminsterDec 20, 2017Luminary
Would it be possible for Netgear to be a little more up-front about what bugs it's tracking here, priorities and any expectations on updates? Lots of issues being reported, but no real feedback from Netgear.
- GKACKJan 12, 2018TutorWhere is the fix for this? A reboot changes my wifi password and devices will not reconnect without resetting the pw. After reset it doesn't appear in the settings the way it was input yet the devices reconnect. But some devices do not reconnect which makes this issue more troubling.
