GKACK
Dec 18, 2017Tutor
RBK50 Orbi Router- Wifi pw does not show correctly in web interface or Genie app after firmware upgr
I have used an 11 character wifi password that includes 2 special characters. No issues until a recent firmware upgrade to the 2.1.1.12 version. I had missed several firmeware versions since the upd...
DarrenM
Dec 20, 2017Sr. NETGEAR Moderator
I know there are some issues with spaces being in passwords and $ signs we are going to fix those in the next firmware.
DarrenM
GKACK
Jan 12, 2018Tutor
Where is the fix for this? A reboot changes my wifi password and devices will not reconnect without resetting the pw. After reset it doesn't appear in the settings the way it was input yet the devices reconnect. But some devices do not reconnect which makes this issue more troubling.
