XeroFire
Aug 09, 2018Tutor
RBK50 Orbi Satellite crashes network
So I have had intermittent problems with the orbi system since the day I bought it, but as of this moment, the main issue I’m having is that the satellite is unusable. As soon as its powered on and c...
Halaqwe
Jan 01, 2019Tutor
I mentioned this to tech support and they said it was not needed only needed if you are doing port forwarding
Jan 02, 2019Guru - Experienced User
Hmmm, doesn't seem like PF would effect how satellites are being connected either wifi or wired back haul. Something I haven't experienced with my system. So there saying if you are using PF configurations, the satellite won't connect properly to the base router in wired backhaul?
Kind of confused here.
