CalvinsPal
Oct 31, 2019Tutor
RBK50 Power
Based upon stellar reviews I purchased and have installed an RBK50 + 1 satellite. I love it, except constantly power cycles itself. It may be fine for a minute, or 45; but, it will power cycle itself...
Oct 31, 2019Guru - Experienced User
What all devices do you have connected to the Orbi system?
- Retired_MemberNov 01, 2019
From the OP..."It has the latest V2.5.0.38 fw installed."
You're NOT paying attention
- CalvinsPalNov 01, 2019Tutor
Likely a canned autoreply, it was sent quite shortly after my post.
- FURRYe38Nov 01, 2019Guru - Experienced User
Would have been nice if you had responced to my "canned" responce. I guess not. Hope you find help with official NG support.
Good Luck.
CalvinsPal wrote:Likely a canned autoreply, it was sent quite shortly after my post.
