xnownxc
Jan 16, 2021Aspirant
RBK50 pulsing white with new IP address
So a few days ago ATT had a outage which completely messed up my orbi’s as usual. But this time I can’t connect at all. My RBK50 has just been pulsing white all day and night. Can’t get it to connect...
xnownxc
vajim wrote:
xnownxc wrote:Yes
do you know about this?
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Ok Ive never seen that double nat link before, so before my system was setup with me leaving the 5ghz on from pace while turning off the 2ghz than I ran my orbi as a seperate wifi. But my orbi is popping up as a 169 ip adress which I know that wasnt the ip before. And the only way I am able to see it is when I view it from my iphone.
As for the access point unfortunately I cant login to the orbi through the orbilogin site or even with a cable attached to the router with a computer. For some reason the orbi wont establish a internt connection even attached through the modem.
vajim
Jan 16, 2021Master
Ok. There are others in here they may be able to offer more help. What you have is a system with 2 routers.
if it were me I would get rid of that modem combo if you can and get a straight modem and run the Orbi with that
good luck
- xnownxcJan 16, 2021Aspirant
vajim wrote:Ok. There are others in here they may be able to offer more help. What you have is a system with 2 routers.
good luck
Yeah Im going to keep looking for a solution. I might try to delete the app or try another device with the reset. Thanks for the help
