jreed336
Jul 14, 2020Initiate
RBK50 (RBR50 / RBS50) Satellite WIFI issues with FW 2.5.1.x
Posting more in hopes NetGear may actually still read these. I've got an RBK50 set up, RBR50 and RBS50. RBS50 is set up with ethernet backhaul. Have had them for a couple of years, and zero issues e...
Jul 19, 2020Guru - Experienced User
What is the mfr and model # of any LAN switches your using between the RBR and RBS when ethernet connected?
Been using v16 since it released on my RBK50. Zero issues. RBS work wired and wireless. I applied manually to RBS first then RBR then factory reset the whole system and setup from scratch. Using manual channels, beamforming and mimo enabled. 40Mhz only. No Armor or Circle enabled for my system.
| System Uptime | 14:01:43:04 |
Even added a RBS20 wireless as well from a CBK40 system. Works.
I still need to upgrade and see if v32 is the same.
