peterloron's avatar
peterloron
Follower
Feb 19, 2019
RBK50 rebooting multiple times per day
I have an RBK50 set up in my condo. Both the base and satellite (wireless backhaul) are on the latest firmware. Muiltiple times per day the router reboots. I know it is rebooting because I can see the "[Initialized, firmware version: V2.2.1.210]" message in the log. There are no errors in the log, just normal messages.
I have done the factory reset. Support has been ignoring my tickets. One was closed with no resolution, and the second one I opened has had no response for weeks.
I'm out of the 90-day free phone support window, but I need to get these defective units replaced.
Any help greatly appreciated!
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    If you live in a condo with many other wifi neighbors you maybe in a wifi congestion environment that would cause this reboot.
    You can set the power output setting of the Orbi from 100% to 50% and see if this helps.
