lwhi021
Dec 30, 2020Follower
RBK50 repeatedly dropped internet after Firmware update a few days ago
My Orbi is connected to a Huawei HG659 modem wifi on that is off and all device connections and DHCP allocation are via the Orbi. I have had the system for some time now and it has been relaible and ...
Dec 30, 2020Guru - Experienced User
If your modem has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first, or #3...
