zap1
Dec 05, 2017Tutor
RBK50 Router & Satellite are showing firmware version 2.0.0.74 on the firmware update page
RBK50 Router & Satellite are currently showing firmware version 2.0.0.74 on the firmware update page. When I check for firmware update, it says no update required. Do I need to perform a manual updat...
- Dec 06, 2017
Thank you both for the quick reply.
Based on what I am seeing here for version 2.1, I prefer not to manually install it at this time.
Hopefully, the apparent 2.1 bugs identified in recent posts are fixed prior to the automatic update roll-out.
This board is a tremendous resource to identify and resolve most issues. I have spent several hours pouring thru the various posts to get a feel for issues and what I might need to do should and issue show up on my system. A big "hat tip" and thanks to all the problem solvers who contribute to this board!
Retired_Member
Dec 06, 2017
zap1 wrote:RBK50 Router & Satellite are currently showing firmware version 2.0.0.74 on the firmware update page. When I check for firmware update, it says no update required. Do I need to perform a manual update to get latest version 2.1.x.x?
When I setup my Orbi system for the first time last week, it correctly showed l needed to update to 2.0.0.74 (the latest version at that time)
If you'd like to yes, or wait for it to be auto upgraded.
