SEAG
Jan 04, 2021Aspirant
RBK50 Router appears bricked, cannot reset router to manually install latest firmware
Hello, I think the last firmware install bricked my RBR50 router. I am unable to communicate with the router either through thte browser or the phone app. The satelite has the magenta ring so I kno...
SEAG
Thanks for the response. I am follwoing these directions but I cannot get the amber light to appear. It just stays a solid green:
- Watch the Power LED. It starts with an orange color, and then start flashing.
So I cannot get to the point to be able to use tftp.
I am using Windows 10.
Jan 04, 2021Guru - Experienced User
I've done it with the light green.
I've also used nmrpflash when tftp wouldn't work.
- SEAGJan 04, 2021Aspirant
Ok, thanks. So you're saying to ignore the fact that I cannot get an amber light or into the factory reset mode? Just confirming. I don't have a lot of experience with routers and networking so I have been following the directions word for word. Again, thanks.
