ericsammons
Oct 16, 2018Aspirant
RBK50 Router losing internet connection after upgrade to V2.2.1.210
Hello,
Recently I've been experiencing issues with my internet connection being lost about 2-3 times per day. In the couple years I've been with this ISP, I've never had an issue. At first I ju...
ericsammons
Oct 17, 2018Aspirant
Unfortunately, my ISP puts their modem in a locked box on the outside wall, so I can't see the manufacturer information.
Before I saw your message, I decided to downgrade the firmware to V2.1.4.16, and after about 20 hours I've had no lost connections. At some point, I'll try to upgrade again and enable Daisy Chain, but hopefully, Netgear will fix the firmware, if that's the problem.
Oct 17, 2018Guru - Experienced User
Ok, please try a FW upgrade if you get time and Enable Daisy Chain. NG is aware of this problem.
