Swanny297
Dec 19, 2019Aspirant
RBK50 Router Mode - ATT Fiber
I just set up my Orbi tonight and did the basic set up with my ATT fiber, turned off WiFi and put Orbi in AP Mode. It is working great. To take advantage of parental controls etc. how hard is it to pu...
Dec 20, 2019Guru - Experienced User
Be sure to put your RBR in the IP-Passthru on the ISP modem when you have the RBR in Router mode. Helps with NAT and connection problems that maybe seen when you have two routers on the same line.
Swanny297 wrote:
I just set up my Orbi tonight and did the basic set up with my ATT fiber, turned off WiFi and put Orbi in AP Mode. It is working great. To take advantage of parental controls etc. how hard is it to put in Router mode? I am somewhat tech savvy but not an expert by any means. I currently have the BGW210 ATT router/modem?
TIA
Clint
Swanny297
Dec 26, 2019Aspirant
Furry
I have ATT fiber 1000. I have the Orbi router connected to the ATT gateway. I have the ATT modem in Passthrough mode.
When I did this I selected the RBR in the MAC address list I didn’t change anything else.
I am getting 985 upload speed and 698 download speed at the ATT gateway but when I do a speed test on the WiFi signal they are both in the 200s - am I doing something wrong?
- FURRYe38Dec 26, 2019Guru - Experienced User
What are wired speeds with a wired PC thru the Orbi?
What wifi devices are you using to speed test wireless? Some devices will max out at around 400-500Mbps. I believe some newer phones should be able too see higher speeds.
- Swanny297Dec 26, 2019AspirantSons gaming computer is wired into Orbi router he is getting 477 down and 460 up.
I was checking them on my iPhone (X) the ATT speeds I checked through the ATT 192.168.1.254 interface.- FURRYe38Dec 26, 2019Guru - Experienced User
Ok, so lets do this, disable pass thru on the ISP modem and configure the RBR for AP mode. Ensure the Modems wifi radios are disabled. Use a wired PC connected to the RBR with both RBSs turned off for now. Lets work with the RBR alone for now. What speeds are seen using this configuration.
