Swanny297
Dec 19, 2019Aspirant
RBK50 Router Mode - ATT Fiber
I just set up my Orbi tonight and did the basic set up with my ATT fiber, turned off WiFi and put Orbi in AP Mode. It is working great. To take advantage of parental controls etc. how hard is it to pu...
Swanny297
Dec 26, 2019Aspirant
493 down and 329 up on WIFI - definitely better in AP
Dec 26, 2019Guru - Experienced User
Those speeds wired?
Have seen some odd issues with these ATT model modems. Only thing i would try if you can, take the RBR to a different location to see if it works with a different modem. Compare speeds. Maybe some problem between the RBR and ISP Modem.
Only other thing would be to file a support ticket with NG and see if the system can be RMAd.
I RBK50 works on my 1Gb speed and see near 900Mpbs and 50Mbps on the UP. So I can confirm mine works, however I use a CM1100 Cable modem which is a modem only. No router built in.
