RLD-rld
Jan 20, 2022Follower
RBK50 Router need dedicated 2.4 Ghz channel
I'm setting up my RBK50 Router. My security cameras requite 2.4 ghz. To my surprise I was able to set them up with little effort. (they were able to pick out the 2.4ghz signal)... BUT, I also hav...
CrimpOn
Jan 31, 2022Guru - Experienced User
RLD-rld wrote:
I also have some WiFi Smart plugs that also require 2.4ghz signal... Now these plugs are not playing well with my set up
As michaelkenward pointed out, Netgear's Orbi products use the same WiFi SSID for both 2.4G and 5G channels. There are two primary strategies that users employ when they have issues setting up Internet of Things devices. (By the way, all Smart Plugs have only a 2.4G WiFi radio in them. Manufacturers have no incentive to spend even one penny on a more expensive WiFi chip when 2.4G offers more than enough bandwidth for a Smart Plug and better range than 5G.)
With the RBR50 router, the usual method is to use the Orbi web interface (http://orbilogin.net). Navigate to the Advanced Tab, Advanced Settings (at the bottom of the menu). Select Advanced Wireless Settings. Uncheck the box "Broadcast SSID" on the 5G channel, and click on "Apply".
The Orbi will continue to broadcast the 5G channel, but will not advertise the SSID. Devices that are already connected will remain connected.
On the smartphone, go into the network settings, "Forget" the Orbi WiFi, then select the Orbi WiFi when it comes up again and connect. Since Orbi is broadcasting the SSID only on 2.4G, the smartphone should connect to the Orbi 2.4G channel
After performing the device setup, reverse the steps.
