lytespeed
Oct 30, 2017Initiate
RBK50 Router Solid Magenta in AP Mode - problem or no?
I have an RBK50 system that I've set up in AP mode...both router and satellite running latest firmware 2.0.0.74. Noticed that the Orbi Router is showing solid Magenta ring which is typically bad - t...
- Oct 30, 2017
You need to connect the Orbi's Yellow Internet port to your router's LAN port.
This is illustrated in the Orbi GUI Access Point setup screen.
