ajcowboy
Sep 01, 2020Follower
RBK50 satellite connection with RBS20
Hi everyone, Needs advice in how to manually connect the RBS 20 to a specific RBS 50, following shows router and satellite positions. RBK 50 router at ground floor (no other choice) RBS50 sat...
Sep 01, 2020Guru - Experienced User
You can't manually assign them. The router assigns them based on a series of factors.
Things you can try?
1. Enabling daisy chainging in the settings.
2. make sure they're far enough apart. They need at least 30 ft between them.
3. you can try decreasing the wireless broadcast power
4. you can also try powering them down and then back up in order.
