Randnik_2017
Dec 15, 2017Tutor
RBK50 satellite down to 2.4 Ghz connection to router
Dear all, Last week the satellite went down in its primary connection to the ORBI router to a 2.4 Ghz connection permanently. I tried all the hints here I could find in the forum: rebooting both...
DarrenM
Dec 18, 2017Sr. NETGEAR Moderator
I suggest contacting support if it is a hardware issue they will be able to troubleshoot with you and RMA the unit if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
