anitachan99
Apr 26, 2020Initiate
RBK50 satellite not stable
I placed and setup my satellite with LED Blue light on, after several hours of usage, my mobile device disconnected with wifi with message "cannot get IP address". Same thing happened after I reboot...
- Apr 29, 2020
Sounds good.
AT some point you can enable Armor and Circle. There have been some resports that Circle has been causing problems. NG seems to be aware of this issue and is working on it.
I would make a backup configuration to file for safe keeping. Saves time if a reset is needed. Then at some point, try enabling Armor or Circle and see how it goes. If you run into something after enabling those apps, You can factory reset and apply the backup confuration from file.
anitachan99 wrote:Thanks for your advice!
I applied your advice and it seems ok. Let's monitor the performance for a longer period.
BTW, by applying this solution, does it mean that I cannot enable the Circle/Armor as you advised disable Circle/Armor?
Thanks .... Anita
anitachan99
Apr 28, 2020Initiate
Thanks .... Anita
Apr 29, 2020Guru - Experienced User
Sounds good.
Thanks .... Anita
