mtsat
Mar 22, 2020Aspirant
RBK50 Satellite shows Poor Delivers Consistent High Speed
Recently ourchased an RBK50. Connected to my provider's modem for 150mb fiber service. The synced satellite connection shows as "Poor" in the web interface but it consistently delivers 100-150mb to l...
- Mar 22, 2020
I have always wondered what "Poor" means. Fortunately, there is a method to determine exactly what the backhaul connection is:
- Telnet into the Orbi router
- Log in using the admin credentials ("admin" and password)
- Type this command
satelliteinfo wifi - This will display information about the wifi link between router and satellite. For example, mine shows this:
/# satelliteinfo wifi
"mac address" : "A0:04:60:0D:96:FA",
"hop" : "1",
"bridge mac" : "A0:04:60:0D:96:FA",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-67",
"backhaul macaddress" : "A0:04:60:0D:96:FD",
"backhaul phytxrate" : "975",
"backhaul phyrxrate" : "1170",
"backhaul parentmac" : "A0:04:60:1C:02:39"
Mar 22, 2020Guru - Experienced User
