meach13
Aug 06, 2018Initiate
RBK50 Satellite Speed
Hi Everyone,
New to the forum and did a little searching. Does Orbi software have or do they plan to add speed between Satellites? I do show it is on 5g but not the actually connection speed betw...
Aug 06, 2018Guru - Experienced User
I agree, would be more helpful.
Another app I find helpful for devices with wifi is WiFi Sweet Spot. It's tests the connection between the device and router or satellite.
Generally, check the routers web page for the status of the connection between the router and satllite. 30feet is a good start, not too close. Mines 40 feet.
