BurtonSnol3orde
Jan 31, 2019Aspirant
RBK50 Satellite will disconnect only when cat6 cable is connected
I have an RBK50 system with two satellites and have recently hooked up a wifi bridge that is plugged into one of our satellites and sends internet out to our barn.
It gave me fits doing simil...
BurtonSnol3orde
There are a pair of Ubiquiti Nanostation M2 one on each end. They are configured in bridge mode as Station and AP on Channel 1 (least usage) and I've narrowed beam significantly.
Can you expand on what you mean by "Creating loops" The antenna are running a totally different SSID that is hidden and password connected.
ekhalil
Jan 31, 2019Master
One more question, are you using wired or wireless backhaul? (the connection between Orbi's router and satellite)
- BurtonSnol3ordeJan 31, 2019Aspirant
wireless backhaul to both sats.
- ekhalilJan 31, 2019Master
Can you please confirm that you have Daisy Chain disabled.
- BurtonSnol3ordeJan 31, 2019AspirantDaisy chain is currently enabled. The main router is in basement.
