ratjunior
Oct 30, 2020Aspirant
RBK50 Satellite
Hi All, I have a RBK50 set. I want to add a satellite to extend my reach. I know that I can use a RBW30 or a RBS40V as satellites. I was wondering if I can use any other satellites that plug dire...
Oct 30, 2020Guru - Experienced User
Yes, the RBW and RBS series are all satellies. The only ones that won't work is the 1 series.
Also the RBS50Y outdoor series works too. Also EX7500, 7700 and 8000 extenders also work too. Though these don't support the backhaul feature.
ratjunior
Thanks FURRYe38,
I think I will be going with the RBW30. I think it will best work for us. Dont need another Alexa something, nor the one made for outside that you mentioned.
BTW: What is the "backhaul" you mentioned? Is it critical for operation? I am not a network engineer!
Thanks!
- FURRYe38Oct 30, 2020Guru - Experienced User
For Orbi units yes.
- ratjuniorOct 30, 2020Aspirant
So do you have knowledge of the RBW30? Good unit? I am very happy with what we have so far.
Thanks
I don't personally. However I believe the EX7500 is kinda close as in hardware wise. I've seen various posts in the forums about the RBW. Kind of a mixed bag on good and bad experiences. Something to try and and if it doesn't work for you, send it back.
