ratjunior
Oct 30, 2020Aspirant
RBK50 Satellite
Hi All, I have a RBK50 set. I want to add a satellite to extend my reach. I know that I can use a RBW30 or a RBS40V as satellites. I was wondering if I can use any other satellites that plug dire...
ratjunior
Thanks FURRYe38,
I think I will be going with the RBW30. I think it will best work for us. Dont need another Alexa something, nor the one made for outside that you mentioned.
BTW: What is the "backhaul" you mentioned? Is it critical for operation? I am not a network engineer!
Thanks!
Oct 30, 2020Guru - Experienced User
For Orbi units yes.
