DavidShawP
Feb 11, 2022Star
RBK50 seemingly dead?
I’ve got an RBK50 with three satellites. It’s worked fine for years but tonight it isn’t responding. When I reboot it the ring light never comes on. I tried resetting by inserting a paper clip with...
DavidShawP
Feb 12, 2022Star
I appreciate the feedback. I tried both methods. It seems it's too dead even for these low level tools.
./nmrpflash -i en0 -f RBR50-V2.7.3.22.img Advertising NMRP server on en0 ... | No response after 60 seconds. Bailing out.
I guess I have to go buy a new router.
Feb 12, 2022Guru - Experienced User
Sometimes it can take a few tries to get the timing right.
Another thing you can try doing is swap the power supply from the router with a satellite. Maybe its going bad and not supplying enough power to boot the router.
