MattHooligan's avatar
Dec 06, 2018
RBK50 Speed Throttling Wired and Wireless
I'm having issues with my new Orbi severely throttling everything going through it, whether it be wired or wireless. I consistently am getting speeds from the Orbi, both wired and wirelessly, at appr...
  • MattHooligan's avatar
    MattHooligan
    Dec 06, 2018
    Solved. I called ATT tonight and they pushed an update through my Gateway that allows router usage through all 4 ports on the Gateway. After this was done, my wired speeds went to around 600, and my wireless speeds went up to around 400.
    Cheers,
    Matt
