MattHooligan
Dec 06, 2018Tutor
RBK50 Speed Throttling Wired and Wireless
I'm having issues with my new Orbi severely throttling everything going through it, whether it be wired or wireless. I consistently am getting speeds from the Orbi, both wired and wirelessly, at appr...
- Dec 06, 2018
Solved. I called ATT tonight and they pushed an update through my Gateway that allows router usage through all 4 ports on the Gateway. After this was done, my wired speeds went to around 600, and my wireless speeds went up to around 400.
Cheers,
Matt
MattHooligan
Dec 06, 2018Tutor
Yep - I've tried #3 and it works, but then I lose all of the Router capabilities that the Orbi offers. This particular model of Gateway (Pace 5268AC) doesn't have bridge mode - they recommend DMZPlus as the only option.
Cheers.
Dec 06, 2018Guru - Experienced User
I presume there is a problem between the Modem and Orbi router. Even in DMZplus, sounds like its still being throttled.
Any chance your ISP supports a modem only unit on there services?
AP mode seem to be the best option. You would have to contact NG and I would contact the mfr of the modem as well and let both parties know that there is a problem between these two units. Short term, you can wait for next FW update. Not sure when that will be.
- MattHooliganDec 06, 2018Tutor
Cheers,
Matt
- FURRYe38Dec 07, 2018Guru - Experienced User
Good to hear. Glad they fixed it.
Enjoy. :smileywink:
Cheers,
Matt
- MattHooliganDec 12, 2018Tutor
FYI - I spoke too soon. The push from ATT caused the Gateway to reboot, which temporarily increased speeds, but it dropped back to the 50MB down limit soon after and stayed there. Upon further research, it looks like a recent firmware update on the 5268AC may be causing this, as other routers are experiencing the same issue. In the interim, I've gone ahead and set the Orbi to AP mode so that speeds aren't limited.
