MattHooligan
Dec 06, 2018Tutor
RBK50 Speed Throttling Wired and Wireless
I'm having issues with my new Orbi severely throttling everything going through it, whether it be wired or wireless. I consistently am getting speeds from the Orbi, both wired and wirelessly, at appr...
- Dec 07, 2018
Solved. I called ATT tonight and they pushed an update through my Gateway that allows router usage through all 4 ports on the Gateway. After this was done, my wired speeds went to around 600, and my wireless speeds went up to around 400.
Cheers,
Matt
MattHooligan
Dec 12, 2018Tutor
I haven't spoken with them again. When I googled 5268AC DMZPlus slow, I got a ton of results over the last month. I'm going to run with AP mode and check up on it again in a month or two.
Cheers.
Dec 12, 2018Guru - Experienced User
Ok, Seems like Pace needs to review there FW and operation with external routers.
Enjoy for now. :smileywink:
