Damit1
Mar 19, 2019Apprentice
RBK50 speeds issues and latest SW
Hi there
So, I have upgraded to Orbiz last FW.
I dropped the issue of speeds, because every 4-5 speed test , speeds are still drops to 600.
Now, upload for some reasom for 2 months is limit...
RAH001
Mar 21, 2019Aspirant
How does one manually set the channel for each of 2.4Ghz and 5Ghz? One of my devices is apparently challenged to connect to 5Ghz routers. I am thinking to set the 2.4Ghz channel to something more common such as Channel 11, in the hopes the device will pick up on that band. PS the device is a Jandy Aqualink (connects our swimming pool through Internet, allowing us to control such remotely from our iPhone).
Mar 21, 2019Guru - Experienced User
On the Basic Tab/Wireless Settings.
You can temporarily disable the 5Ghz SSID from being seen to test under Advanced Tab/Advanced Settings/Wireless Settings. Uncheck the Enable 5Ghz SSID check box.
- Chuck_MMar 21, 2019Mentor
Hey you said you updated the firmware but never said what version you were on. Can you please check both your router and your satellites and tell us the version numbers you see there?
