gjrandazz
Apr 05, 2021Aspirant
RBK50 Streaming between devices
I have the main router(RBK50) and 2 satellites (RBS50). I have this problem and I'm not sure it's the orbi, modem, or connection. When trying to stream games from one device to another, both wired, I ...
Apr 05, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
gjrandazz
Thanks for quick reply. My ISP is Optimum. I use my own cable modem (netgear sb8200). Router to satellite is over 30 feet. House is a single midsized 1 floor. I have beamforming, mimo, upnp, and wwm enabled. Daisy chain and fast roaming are disabled. Firmware of router is 2.7.2.10
- FURRYe38Apr 05, 2021Guru - Experienced User
As a test, turn OFF the RBS and connect your PC and Nvidia device to the RBR and test with these connected at the RBR. Any differences?
Do you have any Arnor, Circle or Traffic Meter features enabled?
- gjrandazzApr 05, 2021AspirantYes, traffic meter is enabled. But same problems when it was disabled
