gjrandazz
Apr 05, 2021Aspirant
RBK50 Streaming between devices
I have the main router(RBK50) and 2 satellites (RBS50). I have this problem and I'm not sure it's the orbi, modem, or connection. When trying to stream games from one device to another, both wired, I ...
gjrandazz
Thanks for quick reply. My ISP is Optimum. I use my own cable modem (netgear sb8200). Router to satellite is over 30 feet. House is a single midsized 1 floor. I have beamforming, mimo, upnp, and wwm enabled. Daisy chain and fast roaming are disabled. Firmware of router is 2.7.2.10
Apr 05, 2021Guru - Experienced User
