blamman
Jan 21, 2023Apprentice
Rbk50 system duplicate ips
I have a rbk50 with 2 ethernet backhauled satellites. About once a month a device cannot connect to the internet such as a firestick or phone. After doing an ip scan of the network and comparing to t...
CrimpOn
Jan 21, 2023Guru - Experienced User
Is one of the devices listed in the LAN Setup table and the other not?
blamman
Seem to be both wifi. I have ip reservations also but that range is not in the dhcp scope.
- CrimpOnJan 21, 2023Guru - Experienced User
Yes, the typical practice is to set aside a range of IP addresses to use for certain devices (i.e. "reserve" or "assign" to these devices based on MAC address) and set the DHCP range of IP addresses so that there is no overlap.
These two devices, then, are not in the LAN Setup table for assigned IP address, but are both somehow trying to use an IP address from the DHCP range, correct?
- blammanJan 22, 2023Apprentice
They are not any of the reserved ip's . The are out of the dhcp allocation and can be different devices.
I do run the parental controls also.
- CrimpOnJan 22, 2023Guru - Experienced User
What tool is being used to scan the LAN? (just curious)
Does the Orbi Attached Devices page include both devices with the same IP address?
This sort of thing has been reported when there is a rogue DHCP server on the network. (some device that includes a DHCP capability that the user had not realized was there and had not intended to activate).
The problem does not resolve itself if those two devices are powered off and then restarted one at a time?
