blamman
Jan 21, 2023Apprentice
Rbk50 system duplicate ips
I have a rbk50 with 2 ethernet backhauled satellites. About once a month a device cannot connect to the internet such as a firestick or phone. After doing an ip scan of the network and comparing to t...
Jan 24, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are the RBS Ethernet connected at the RBR or is there a LAN switch in between the RBR and RBS? If there is, brand and model please.
blamman wrote:
I have a rbk50 with 2 ethernet backhauled satellites. About once a month a device cannot connect to the internet such as a firestick or phone. After doing an ip scan of the network and comparing to the assigned device list in orbi two devices are fighting for the same ip address. The only way to correct is the power off the router and satellites for a few minutes then power them all back on. Any ideas on why this is happening?
Thanks
