JD2195
Dec 09, 2019Follower
RBK50 system with new increased Gigabit speed
I recently updated my Internet to Gigabit speed. My computer hardwired to modem clocks an average of 900 MBPS. I understand the WIFI won't likely match those speeds, but what is realistic with this Orbi system. I believe it supports up to 3 GBPS? My devices have not broken past 500 MBPS.
JD2195 wrote:I recently updated my Internet to Gigabit speed. My computer hardwired to modem clocks an average of 900 MBPS. I understand the WIFI won't likely match those speeds, but what is realistic with this Orbi system. I believe it supports up to 3 GBPS? My devices have not broken past 500 MBPS.
Thats about what you can expect out of wireless.
They get the 3000mbps by this route: 1733mbps 5ghz (backhaul) + 866mbps 5ghz (fronthaul, usable) + 400 mbps 2.4ghz (fronthaul, usable).
If you're getting 500mbps over the 866mbps 5ghz front haul, thats about what you can expect. Some can get slightly more depending on device and environment they're in.
The orbi isn't necessarily going to give you the highest peak performance. the flagship single router solutions are. But what orbi is going to get is you is the most consistent and widest coverage. Also it'll get you client roaming and single ssid solutions.
You should see near 900Mbps with a wired PC thru the RBR50. This will be the max ever seen on Orbi with a wired PC.
The max download I've got wired is ~900 and the max upload ~940. For brief milli seconds I've hit 1.5 Gbps on Fast.com. Even on upload I've touched 1 Gbps more than once.
On WiFi, the max I've got is nearly 600ish. For brief mili seconds I might have crossed 650-670 or so.
Orbi 5 GHz radio (client end) has a 2x2 radio. The link rate is 866 Mbps. Usually 1/3rd goes to overheads. So 550-600 is usually the max you'll get. If you're unlucky you might get 3xx/4xx I guess.
All of this is in the same room as the router/wired satellite.
a satellite on wireless backhaul might give much lower speeds than the above.
Here is a strange thing. I have 1G service, have for over a year now. Orbi system for about the same time. Whenever I ran the speed test on my Orbi app I saw download speeds of around 490Mbps down and 32Mbps up.
Since the last firmware update I now see download speeds of just over 900Mbps. I do not understand how or why. I'm not complaining you understand, I'm just confused.
I have changed nothing, no settings change, no reboots, nothing.
