xPhilx
Nov 26, 2018Aspirant
RBK50 Technical Information / DFS Channel Support
Greetings Everyone,
I am a network engineer that currently has Ubiquiti systems at home as I do like to perform more advanced changed on my network. I have been planning to invest on a robust M...
xPhilx
++ Corrected several spelling errors - Sorry. Typed this at 6AM ++
Greetings Everyone,
I am a network engineer that currently has Ubiquiti systems at home as I do like to perform more advanced changes on my network. I have been planning to invest on a robust Mesh Wifi System, and the netgear - spec-wise - seems to meet most of my concerns. the RBK50 running latest OS offers: Tri Band support, two large MAP bridging to the RAP, it does provide gains on the reception.
I tried to find some screenshots of the OS running Netgear, I have a few questions about what is supported / able to be done with the app or web interface, would someone be able to answer:
- Can you select the Backhaul channel or is it automatic? Does it allow Channel Bonding?
- Does this support 802.11ac Wave 2 (Up to 160Mhz) ?
- Does it support setting manual DFS channels for SSIDs? How About Backhaul?
- What is the number of spatial streams in here? 2x2? 3x3? How about the backhaul network?
I know most people don't use DFS because they are oh so afraid of the satellites coming by, I live miles and miles away from any radar or any system that could interfere with DFS, so it's not a concern for me at all. In fact I have used it for the past 2 years without a single issue. I live in a condo are where many people love to channel bond to 80mhz, so there is an inferno of co-channel interference on the 5Ghz but DFS range is clean as a whistle, my main goal would be to :
- Channel Bond the Backhaul network using Channel 52 and up (hopefuly to 160Mhz, if not 80Mhz)
- Channel Bond my 5Ghz WLAN using channel 116 and up (DFS Range, again up to 160Mhz if possible)
Netgear, please make better technical information
Not all users wan't to feel like you dumbing us down.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
